4X4 not working when very cold | Ford Explorer Forums
weaselfox
Pittsburgh, PA
93 XLT
OK This Just started happpening since winter kicked in up here in PA 4X4 worked great in the summer. Its been freezing or below for a while up here and sometimes my truck sits for a week or more. I started it today (its about 17 deg) and It would not engage, no 4x4 lights, no noise nothing. After driving for about 25 min to work and everythig was hot I hit the button and wa la it goes right in with no problem. I read the sticky but not sure which case would be affected by cold temps. My guess is shift motor.
You are correct.
When the T-case is very cold the shift motor will need more power to rotate it's Selector shaft. If the shift motor cannot shift into 4H within a ~2sec time limit the 4x4 computer will believe there is a problem and return to 2H.
Before cleaning the shift motor your can help shift better by switch in/out of 4x4 several times to help free up the motor. All to often people ignore the 4x4 system until they need it. By using 4x4 once or twice a month it will ensure it is working smoothly and not give you any surprises.
Thanks for the expert knowledge and tips De Rocca. I will engage it more often, and clean it too (Ill take my laptop out to the garage with me so I can read the rebuild thread)
