4x4 switch reassembly help!! | Ford Explorer Forums
Ksprague994
Location
Nashua
Milford, New Hampshire
2000 Explorer 4.0 V6 SOHC
So I removed the 4x4 activation switch and took it apart to change the little green light bulb behind it and now it won't turn after reassembling it. Idk how it went back together and getting sick of the flashing lights on the dash. Any help would be appreciated, thank you
Time for a new switch sounds
like
There's a little check ball with a spring that you must realign in order to get it to work right. I don't have to worry about that bulb because I hard wired a quality LED in it's place. Lasts a lot longer than on of those micro bulbs. The condom is what causes them to overheat and burn the bulb out.
