tweakedlogic
- November 4, 2003
- memphis, tn
- '92 XLT
This morning i went to work in 4WD due to snow and ice. When I got to work I turned it off and reversed for a few feet to disengage the hubs. I had to leave to get a part and put it back in 4x4. Again, when i returned to work I turned off 4x4 and rolled backwards. When i leave work, I push the button and nothing happened. Pushed several times, cycling the engine on an off just to make sure. I went ahead and drove home in 2WD with a 10' trailer in tow. Not as easy as with 4x4.
Got home and fiddled with it some more. Tapped it with a hammer several times, disconnected the switch a couple times. I did not check the control unit because there is stuff back there and it is cold and dark.
The only thing that changed from the time I turned it off the last time to when leaving work, is i pulled it in and put it on the rack to check the tranny fluid and t-case fluid. I added about a 1/4 quart to the t-case.
I can't under stand how it could work perfectly all day until I need it most. I have to haul this trailer all over town tomorrow. I need my 4WD.
I have searched, I came up with nothing except to rebuild the shift motor. i can't take it apart right now, and I will have a very hard time fitting that into my schedule tomorrow.
Could it be something easy just this once?
