dfisher8871
- March 25, 2009
- palmyra
- 1997 xlt awd 5.0 v8
Dodge Ram 1500
Engine: 5.0L Cummins 90-degree V-8
*At least 320 hp and 500 lb-ft
*Aluminum heads and an iron block
*Exhaust gas recirculation (EGR)
*Cummins-built variable geometry turbo located in the engine valley
*Catalytic converter and diesel particulate filter (DPF)
*Common-rail fueling with piezo injectors
*Engine weight 710 pounds
*Selective catalytic reduction (SCR) through the use of liquid urea
*Chain-driven single overhead camshafts
*Six-speed automatic 655RFE transmission
*10 1/2-inch ring gear diameter in the semi floating AAM rear axle
MPG: (Diesel Power December 2006 issue titled, "New Cummins V-6 and V-8") A Department of Energy test found the 1/2-ton Ram delivered 24.6 mpg
so how do you guys think of this moter for a 1997 5.0 awd as a replacement moter
