Makahveli
- July 19, 2002
- Denver, CO
- '92 Sport and AMG 300CE
I was wondering about the extended brake lines, do u need to get hose if you don't go offroad and never disconnect your sway bar links. And another is with the drop brackets.... the nuts and bolts that they included in the set threw me off. I got two axle drop brackets and two radius arm drop brackets. ok they gave me 16 nuts and bolts at one size and then 4 more bolts at a larger size, 2 washers that were too small for the bolts and I'm assuming like 4 washers short of the 14 bolts. I can probly figure out the the 16 bolts of the same size, but where do the 4 large bolts go? and the two small size washers?
