5r55w output shaft ring | Ford Explorer Forums
aag
NJ
04 Ford Explorer
Hey guys
I'm currently rebuilding my 5r55w. I'm trying to get my output shaft snap ring on but I need literally a smidge more space to reveal the groove. My rear planetary ring gear needs to get pushed back just that LITTLE bit more but how if I can't go anymore? Anyone else have this issue? Or if you did how did you do it? I put everything in correctly and it's all as far back as it goes. Any feedback would be awesome! Thanks so much!!!!
Are you sure the bearing under the ring gear is correct and the sealing ring is in place?
