Hawkeye61
- December 4, 2010
- Vandalia, MO
- 2002 XLT
Just thought I'd share my solenoid pack experience in hopes it may help others.
My 2002 Explorer XLT suddenly had harsh shift going into reverse and into 3rd. The O/D light was flashing as well. I knew the problem was in the solenoid pack after doing some research so I tore into it.
After removing the solenoid pack from the vehicle I did a bench test on the pack using this video from youtube ... https://www.youtube.com/watch?v=3trapVvjJMM as a guide and found that the PCC (Pressure control solenoid C) was not working.
Since I am a tight wad I decided to see if I could repair the pack instead of replacing it.
The white arrows in the photo below shows some locations for some plastic caps that I had to grind off and the red arrows show locations for tabs that needed to be released.
Once I had them removed and released I was able to remove the plastic covers (2 of them) that cover the electrical routing of the solenoid pack.
In the upper left corner I noticed a break connecting one of the terminals to Solenoid C. Ah ha!
After soldering up the break, touching up some other weak looking spots and cleaning the pack, I super-glued the plastic covers back on, reinstalled the pack, put in a new filter and fluid and Bingo! Working like a charm once again!!
