Explorer_PL
- November 16, 2007
- Rockland County, NY
- 06EB V8
I hope this will help some of you guys with 4.6 / 6R60 combo. About 1-2 months ago, my truck went into a limp mode while driving on the highway. I restarted it but it was still violently bucking and kicking, almost ripping the tranny out of the truck. I went to Ford dealership to have it diagnosed and the certified tech comes back and says he can't communicate with TCM, so most likely the TCM inside the tranny is shorted or cracked from the heat. It would cost $2000 for the part plus $ 350 labor, but he said at this point, it's better to replace the whole tranny for $ 4,800. I figured, Ok, at 214k miles maybe that's it for the original tranny so I started to look around. Most of the shops quoted me 4600-4800, while Ford actually came down to about 3,900 for the whole job. But I was still hesitant since most of the time the tranny would work perfectly, and then it would buck when I tried to accelerate on the highway. Also, it would go nuts kicking and hunting for gears when trying to start up after a short drive. Usually, while cold in the morning it would work. I started my internet research. Most suggestions pointed to mechatronic assembly so I found a rebuilder and got a new one for $ 500, and replaced it.
It improved overall shifting but it still was going to fail mode. So I called them and ordered a free replacement, which they shipped and I replaced it again - did not change much.
See my other thread here:
http://www.explorerforum.com/forums/showthread.php?t=436342&highlight=mechatronic
Then I came across a note from another user here who fixed the issue by fixing the 2 wires going to TB assembly on the driver side (not the TPS wires). They tend to melt from heat and fuse together creating a slight short, and since tranny is reading signals from everywhere, that was part of my problem too. I split the double wire and insulated it so they were apart from each other and immediately, most of the kicking went away, but would still go into a limp mode quite often.
The I came across this:
https://certifiedtransmission.wordp...ion-u-codes-caused-by-faulty-ignition-system/
I also pulled the codes again using forscan, and saw U0101 and U1900, exactly as in that article.
I ordered set of 8 new original Motorcraft coils, I had 8 new Motorcraft spark plugs in the garage from the past, and replaced all. It's been a week, close to 700 miles and it did not kick, jerk, buck or throw a code even once. I hope this is the end of it although you never know.
But for now, the tranny with 217k miles shifts like it did 9 years ago. As you can see on the picture in the article, the TCM harness runs on top of # 2,3 and 4 coils. If they are bad or cheap, they will generate some type of electrostatic noise that confuses the signal going down to TCM. It may be a good idea to build a bracket to route the harness further away from the coils.
I hope this will help someone, it worked for me.
And I was close to shelling out 5 grand, and the problem would still be there.
