91 & 95 Explorer FRONT slip yokes interchange ? | Ford Explorer Forums
chevyh8ter
97 ford explorer
I'm trying to make a custom driveshaft for my 1990 Bronco II.
Can someone tell me if the "FRONT" driveshaft slip yokes will interchange from generation 1 and generation 2 Explorers ?
From what I understand the 95 (2nd Gen) has a shorter main shaft. Thats what I need but I also need the 91 (1st Gen) slip yoke because it too is also shorter.
I'll be putting the two together to make a short u-joint shaft.
Thanks
Thanks
The second gen came with a 4405/4404 it had a cup yoke like my 05
I have a 91 front driveshaft up for grabs if you want it.
