Bronco_bill
- October 31, 2000
- New Jersey
- 91 XLT,97 XLT
I just bought a aftermarket system of ebay but want to confirm a few things before I install it since this is the first time I've put one in. The directions I got with the kit just suck so I went to www.bulldogsecurity.com and downloaded a wiring diagram to start. All my instructions have in them is wire colors and what to conect to. Here is what I am unsure of:
1) Connect to true ignition, the system ignition input?
The chart I have from bulldog says this is a RED/L green on the ignition harness. I take this to be the harness that plugs into the ignition switch?
2) Dome light supervision output (-) 500 MA chart say's connects to Blk/L blue at the pin switch?
3) Chart has nothig about this one? I have a wire for
(-) and (+) door trigger. do both get hooked up? One to the - and one to th + wire at the pin switch?
4) Door lock/unlock wire just get connected to alarm leads?
5) I have a channel 2, a channel 3,(trunk release? and somthing else?), a secondary trigger (second shock sensor?), and a wire that is Armed output (-) 500 MA, shows low when system is armed? would like to know what that means?
