91 ex trouble code help | Ford Explorer Forums
tuck817
Ft.Worth TX
91 2 door 4x4 xl
So after rebuild and install I'm pulling two codes 67 and 85. I'm not the dumbest person here but was wondering if there were any common issues with these codes. I'm pretty sure I need the new purge solenoid but the other one I don't understand, neutral safety switch maybe? Any help from you guys is always above any "mechanic" I take it too.
I can't really help you on the purge valve. There's some tests that can be done but I can't remember them.
For the 67 code, try to start the engine with the vehicle in gear (be careful!). That will give you an indication if the switch is bad.
So that probably explains that too the reason I rebuilt was the power steering leak ate through the timing cover so figured do a mild build. But also power steering fluid ruined my alarm system so with it not being able to start from alarm I installed push to start. So with key on it'll start any gear.
