91expy
- January 16, 2006
- Michigan
- '91 Eddie Bauer
91 auto exp eb
It has a very high idle when you start it up and sits around 1500-2000K. I reset the EEC and it went away for a bit, and the problem returned. Today i took off the IAC and cleaned it out i was built up with carbon. When I put it back on it didnt solve the problem, but if i unplug it i can idle @ 600rpm. Also for some strange reason when the truck is running it spit up antifreeze from the overflow, i mean gushing out. Its not my truck and my sister took it in for an oil change and she can remeber if they added any fluid. I have never heard of a coolant overflow with out someone over filling the bottle. I also hear a slight hising from the brake booster gromet should i replace the hose and grommet or just rtv the gromet? Theres one other stange problem, on the coil pack (if your facing the vechile under the hood) the farthest in the back to the drivers side has corrosion dust when you pull the plug wire. I have dielectric and it is still firing the spark plug, should i be woried about it? No other coil socket has the problem. One last question does anyone know why the anti theft sometimes chirps, and other times dosent
maybe a bad siren?
anyways TIA
maybe a bad siren?
anyways TIA
