91 Explorer ignition cylinder gear & actuator lever removal | Ford Explorer Forums
rhuck60
DeQueen AR
91 Explorer
can any member help me to remove the small gear that is located behind the lock cylinder?
and also the actuator lever it moves.
I have torn the whole column out and pretty much all to pieces but still cant get these 2 parts out.
behind the lock cylinder it shows the gear, a bearing and a (plastic) retainer.
I cant take a chance to damage these parts, they are all obsolete.
the actuator lever must come out straight up the column towards the driver but a spring is pushing against it.
about half the time the whole mechanism locks up and wont move.
it must be junked out inside
this is my 3rd day and I cant figure out how to get these parts out.
Have you tried a boneyard for a used column? That may be your best bet. I don't remember reading about anyone trying to fix the wheel lock on the forum, but maybe someone has:dunno:
I havent tried for a used column due to the cost
I found a NOS lock actuator lever at the local dealer for under $20
the gear is not available and the last price was $62 wow
locally there are no good options for reasonably priced salvage parts
I might have to go out of town if I need the small gear
it just seems excessive to replace it all for 2 small parts, 1 of
which I have new.
even if the column is basically just hanging loose.
thank you for the suggestion
a colum with key ?
you mean that you cant pull the tumbler ? without a colum swap what about after pulling the steering wheel ?
