merc2dogs
- October 22, 2004
- grand rapids Michigan
- 91 eddie
Hello all, new here, been searching the net for the last couple days to looking to fix this problem, been dealing with it for a few weeks now, and haven't made any headway on it
The problem is that it takes a lot of cranking to get it started, once it starts, it runs fine, extremely well even. I drive anywhere from 80 to 150 miles a day for work (round trip Holland/lansing etc, I'm in construction), and while it's running there's nothing at all to complain about, and great mileage
also, when I first had the trouble I pulled codes, and all I got were a bunch of old codes,and one 'new' tps code, cleared codes, replaced tps, drove it for a while, pulled codes again, and nothing came up as wrong
the main symptom is that I get 2 or 3 nice sparks when first turning the key,then no sparks, with an occasional yellowish, sputtery spark every now and then.
it will start with long cranking, but I have a better chance with short kicks, I've burned out too many starters in the last week and a half from the cranking, (lifetime warrenty thankfully!)
I swapped out the ignition module (had one from a known runner), then had that one checked as it didn't solve the problem,
borrowed an ecm, and that had no effect,other than one 'normal' startup, so I swapped back to my old one.
everything I checked out came out good, the only problems I can find is that on the wires to the crank sensor, I have 1.5v on both leads (to ground), instead of on 'one' wire as stated in the haynes manual.
and that I am getting the same 'signal' at the coil low side as I get from the spark test (couple sparks, then a few every now and then)
as far as the crank sensor, I've been given differing specs, most claim that I should have some resistance accross the lugs, others say only that I should have a voltage pulse when cranking the motor. I have 0ohm resistance, but get voltage pulses of roughly 500mv, which makes me think that's ok
did try running a hot wire to the coil instead of the ignition wire on the off chance that I had a low voltage feed, with no change either
frankly, I've checked everything I can think of, and can't find anything wrong except for the voltage on both leads for the ckp.
any help is greatly apreciated, it's getting way too cold to take the bike to work anymore!
thanks
merc.
thanks
merc.
