I had a slight drip,but after my car overheated it became worse.I corrected the overheating issue with a coolant flush,but now the check engine light comes on and I believe it is due to the leak nar the oil pan which is more than slight.After being parked there is a oil leaking on the ground,I tried to looka nd it seems likethe bolts or nuts is where it is leaking at,although I could be wrong?
Does anyone know what this could be?
I do still drive my truck
