:exp: Hello -- My son gave one of his friends a jump start and now the Ex will shuts off intermittently -- Haven't tested yet but I think alternator -- any suggestions? Thanks
I guess it could be, To check the alternator while the engine is running, you should see about 13.9 to 14.7 volts at the battery terminals. I wonder if your problem lies elsewhere though. Did anything get damaged or burnt when the vehicle was jump started? Where they touching?
I would try moving the wires around while the truck is running to see if you can make it die. I wonder if you are losing a power connection to the under hood fuse panel or something. Both the fuel pump circut and PCM supply circuts get their power from that box.
I got it all wrong - trouble is the X will intermittently not start -- I tried the screwdriver across the starter relay terminals and it worked about 3 times. I was ready to replace the relay but now it won't start like that anymore -- After researching on the site I think it's time to just replace the starter and be done. Any thoughts?
found a broken wire near the starter - repaired it and thought I had trouble solved but not - tried to jump across the starter leads but starter drags for a moment then relay back to single clicks -- will ordr replacement cables from napa (think I need them anyway) -- more to follow
