R&T Babich
- February 1, 2007
- Thousand Oaks, CA
- '92 & '93 XLT 4DR
Hi, to everyone, we're new to this forum.
My wife's '92 Explorer XLT 4x4 with 202,000 miles has been a great car. We've replaced the battery, alt, starter, A/C, P/S pump, muffler, several sets of front brakes/rotors, oil every 2k, filters - all the normal wear and tear stuff. The engine, trans, radiator, hoses, rear axle, front axle, catalytic converter are all original. This is the first time I've had to hook up the code reader (Innova 3143).
The problem we're having is a rough idle and bogging when trying to accelerate from a stop. The CHECK ENGINE light is on. The CHECK ENGINE light had come and gone a couple of times, but is on solid now. When the CHECK ENGINE light was off it would run fine. My wife works 2 miles from home and it hasn't been above 30 mph since this started. We stopped driving the car so I don't know how it performs at speed. Dug out the reader and found the connector. The KOEO test with the reader shows codes: 111, 157 & 158. Codes 157 & 158 seem mutually exclusive. My first thoughts are "Bad MAF" or the wiring harness has a broken wire. The wires hanging from the MAF connector are under more tension than I think they should have, but there is no easy way to support them. I've visually inspected the wiring harness and all looks good. I have 2 other MAFs to try after running VOM tests on the wiring. The Haynes I have seems to describe the procedure well. One of the MAFs shows 3.9 ohms from the SIG pin to the two GND pins. I'll ohm test the MAF on the car (and the other one when I find it) and run the voltage tests this weekend.
