92 Explorer trans ques | Ford Explorer Forums
gforceman
Virginia beach VA
2003 limited 4.6 V8
What is the correct model of tranny for the 92 EX 2WD is the number located on the tail housing ? i did see numbers there and it DIDNT say A4LD the tranny was a junkie replacement by the junkyard. ill post the number later
The A4LD is the only transmission used in the first generation Explorer. I dont think our transmissions have any stampings that actually say "A4LD", "4R55", "5R55", etc... But if its from a 1st generation Explorer, that means it has to be the A4LD (only one engine and one transmission available). There is typically a "badge" on the body, closer to the bellhousing but still on the transmission's body... maybe 3x2" rectangular, but I'm not sure if this badge will have the transmission model.
