It will, but the combustion chamber on the older head is larger. It will lower your compression.
I wouldn't do it. If you can find a 95-98 head, it has the same sized combustion chamber that you have, and larger exhaust ports.
Im betting any head you find in a graveyard will have a crack in it anyway, unless the old owner went with an aftermarket casting before the vehicle was junked.
The factory castings crack. Its just what they do.
