92 LX 4wd issquirrely at highway speed | Ford Explorer Forums
tweakedlogic
memphis, tn
'92 XLT
92 4wd is squirrely at highway speed
I have 31x10.50s on a stock lift (not for long). i know the shocks are going quick.
Above 60 she swings and is unhappy. I am unhappy below 75 so we have a problem in our relationship.
She needs to handle better at speed. Tire pressure is good.
What can I look into. the radial arms and bushings have been replaced. That is all that's that's been done.
Help.
swervy bump
What is your tire pressure. Mine is lifted but likes to wable if the tire pressure is to low. Mine drive best at 35-psi.
If you know the shocks are going bad, get them replaced. Bad shocks can contribute to steering troubles.
Also check:
wheel bearings tight?
Ball joints tight?
tie rods tight?
at that age, steering gear box tight?
steering column tight? there are some rubber bushings in the column that will get sloppy when the rubber gets rotten.
