'92 v6 starting problems | Ford Explorer Forums
casey2008
Alaska
1992 ford explorer
Okay so the vehicle will not start. A couple of days ago it was running fine, then my friend left the key on overnight and drained the battery. Got it charged back up and it started then I parked it and next morning it wouldn't start. When I turn the key absolutely nothing happens. I just had the starter replaced about a month ago, and the battery is putting out proper voltage. However, I turn the key and nothing works. No clicking, no lights, it is as if the battery isn't even there. Any suggestions? Any help will be greatly appreciated.
Do the interior lights come on when you open the door? If so, have a look at your starter relay. Else, check the cables from the battery. They must be broken somewhere if you are certain the battery is charged.
[edit]
Also: Check this thread: http://www.explorerforum.com/forums/showthread.php?t=146784
