bwphoto
- May 23, 2003
- Troy, Michigan
- 1992 Sport
I'm driving a 1992 Sport 4x4 5speed with about 185,000. The trans was replaced last February. New starter, batttery, exhaust since then. When I'm driving, the car starts vibrating at random speeds, usually not under 1500 RPM and it also usually starts out at a pretty slight vibration, then gets stronger until it seems to reach a peak. Occasionally it will just stop vibrating for a while then start again. Also, it doesn't happen (or isn't noticeable) at speeds less than 20mph, but does happen at everything above that.
When I press in the clutch, the vibration stops. When I rev the engine with the clutch in, the vibration stays stopped.
Any ideas? It's at the trans shop now but I can't afford to get hosed. I'm planning on doing an engine rebuild during my Christmas break from school, so if I can garage it or drive it very infrequently until then (won't be hard) that would be great.
Thanks for the advice.
Kevin
Kevin
