deerejohn606
- December 11, 2002
- Corinth,Maine
- 92XLT/96 limited
My x has been hard to start for quite a while but now it doesn't want to run at all.The last time it ran all was well after a hard start. Fires but doesn' t won't run. Shot of starting fluid fires it up then sounds like it runs out of fuel.tripped the schrader valve on fuel rail to find just a dribble of fuel. Sounds like the fuel pumpruns for about 5 seconds and stops, just like it always has. how do I check the pump independent of the system while still in the tank. I can't tell if the pump is weak, the fuel pressure regulator is stuck and is bypassing by the rail and returning it to the tank. I'm trying to avoid replacing everything one piece at a time, only to find I've spent $300 and careful proceedures could have diagnosed a quicker and cheaper cure.
Also feel free to E-mail me at deerejohn606@aol.com As usual thanks for your help!!
