92 XLT help!!!!! | Ford Explorer Forums
92 XLT help!!!!!
slammin
pittsburg, ca
92 XLT
Hello X owners,
I recently bought a 1992 XLT with 100,000 miles a few months ago. It was well taken care of. A few minor malfunctions have come up recently and maybe someone can help me out. They are:
1. The right rear signal flasher light does'nt work. I check the flasher fuze and its fine. The rear lights work fine. The left signal rear light works as well. What might be the problem?
2. The Air Con is no longer cold (not like it was too cold to begin with). What type of service do I need to get the AC to work cold again?
3. The idling sound coming from under the hood (whining) is louder than ever. In general, I know Explorer's have somewhat of a loud engine idle but this is embarrassingly loud. What could it be?
Hope you can help
Sam
novice mechanic/new explorer lover!
rhythmslam@attbi.com
Hope these ques
1) The bulb in the rear has two elements inside the bulb, one for the tail light and one for the signal/brake light. Unless you've pulled the bulb and verified that both elements are good, that's the first place I'd check.
2) Probably just low on freon. If you're taking it to someone, a basic A/C service should confirm that for you.
3) Hard to say. With the engine off and cold, grab the fan and see if you can turn it. If not, then maybe a new fan clutch will help. I just recently replaced my fan clutch and my idle grew louder because now the fan spins faster than it did.
