Christobal
- July 23, 2007
- SoCal
- 93 XLT, 03, 2 wheel drive
For a few years now but probably only 5-10 K miles, total, since it's a low use vehicle now, when the engine and trans fluid are on the warm but normal side, the trans will do a stutter step or two on the way up through the gears. I don't believe it's slipping, because it doesn't feel that way and the trans hasn't destroyed itself, but it was definitely never that way during the early years. Lockup function is normal. This stutter step usually kicks in right after it shifts to 2nd and remedies itself usually before it gets to 3rd, IIRC. It's like there's an extra downshift and then upshift all while still in 2nd because all the other normal shift can be accounted for including the lockup function.
This trans was rebuilt (probably unnecessarily in my opinion) by the dealer under warrantly at approximately 30K. It has 170K or so on it now.
Does this sound familiar to anyone? I've heard these trans aren't considered to be bullet proof and are known to have problem areas/weaknesses. I've considered purchasing a Transgo kit which I believe stated it corrects specific issues with this trans along with firming the shift to one degree or another, which I'd like a bit of, but nothing harsh.
Anyone installed a Transgo or other kit for this trans and had positive results?I'm getting ready to install a new radiator soon, and so will have the cooler lines off, and might as well go in the trans at the same time and change the fluid add a shift kit etc.
