wrorke
- November 23, 2006
- danville, ca
- Ranger '93 XLT SprCab 2WD
KOEO = 111
CM = 214
KOER = 538
No "goose" test performed
These indicate a problem with the Cylinder Identification (CID) circuit. My Haynes manual says the Camshaft Position Sensor (CMP) is what is referred to as the CID sensor.
I haven't pulled my intake manifold yet to get a clear view of whats behind it, but looking around it with a mirror, I don't see a Camshaft position sensor. My Haynes manual indicates a '93 4.0 Auto Ranger (California) would not have one.
Does my truck have a Camshaft position sensor? If not, why am I getting these codes? Or do I just need to bite the bullet, pull the manifold and drop $300 on a new Camshaft Position Sensor.
Symptoms:
Any advice would be appreciated.
Thank you. Happy Thanksgiving.
CM = 214
KOER = 538
Symptoms:
CEL comes on about 15 sec after start and stays on pretty much continuously. Engine seems to run fine.
I have always gotten a CEL when oil is a quart low (about 3K miles, if I'm procrastinating on the oil change); topping off used to correct the CEL, but not this time -- I added a quart, level is spot on, but I still get CEL.
I am also starting to get CEL after starting downgrade after a climb.
160K miles.I have always gotten a CEL when oil is a quart low (about 3K miles, if I'm procrastinating on the oil change); topping off used to correct the CEL, but not this time -- I added a quart, level is spot on, but I still get CEL.
