93-94 LTD Explorers wiring question!!?! | Ford Explorer Forums
asp84
Tempe, Arizona
1998 V8 AWD Mounty
A while back ago, I transferred evey wire harness from my friends 1994 Limited, to my 1991 Explorer body. (Yes, I even took out the dash, and every interior panel to replace 100% of the wiring)
Anyway, For some reason my dome lamps and door lamps don't shut off. They are pemanently ON! (even when I am driving) Luckily the Limited edition's have a battery saver device, and after 15 minutes it turns the interior lights off when my car is off. All my door pins are connected to the harness. Yes, I even replaced the door pins with 94 LTD door pins.
My QUESTION is ...... What factors control the Interior lights in a 93-94 Limited Edition explorer. What makes this complex, is that the Factory Keyless entry and Anti-theft system also take a part in controlling the interior lamps.
Any suggestions?
you checked the headlight switch? isn't there an interior light switch built into it?
lol........ yes the headlight/ dome lamp switch is off... I wish it were that easy!!!
unfortunately i'm having the same problem, it started yesterday and i just cant figure out what is wrong
Well. I figured out what it was. I broke out the wiring diagrams and bought a mutlit-meter. Turns out it was a faulty frotn door pin sensor after all.
Good Luck.
Al
