ggaarryy
- June 24, 2004
- new york, new york
- 93 eb
93 Explorer eddie bauer with 160k. Stepped on the brakes today and they went all the way to the floor and huge puddle appeared under the rear (i think i am calling correctly) transaxle.
There is a box on top of the transaxle from which the hoses for the two rear wheel brake lines go -- it appears the leak is coming from there (specifically the fitting to the rear passenger wheel it would seem). Questions:
1) any suggestions on the procedure for removing/replacing the lines? Do I need to replace the box on top of the transaxle too?
2) when I checked the fluid a couple of weeks ago, it was dirty brown. Assuming that is contamination -- what should i do to restore the rest of the system once i fix the back brake hoses? Does the contamination mean I will need to replace the master cyliner as well?
3) there is reference to a special tool for brake work -- is this a 'generic' special tool i can pick up at autozone or something unique to ford explorers i need to get from a dealer?
4) would no rear brakes make my brake lights stop functioning (which is the case)?
5) a somewhat related brake issue -- i've noticed that hitting the breaks does NOT disengage cruise control -- any relationship?
With the help of this great board, I was able to replace the fuel pump a month ago so I hope I can get some more advice here. Thanks in advance.
3)
3)
