Okay... I did some troubleshooting and it wasn't a shorted wire pair, it was the module itself. I grabbed that one out of the 94 limited and it works great! Thanks for your help Will. To cover myself in the future, I think I'm going to get another anti theft and keyless entry module for backup purposes just in case I have problems again. Somebody already put duct tape over the anti theft module in my truck a looong time ago because there was tons of dust over the top of it. I laughed when I saw the tape but it just goes to show you really can use the stuff for almost anything. Don't know why they didn't do the keyless module while they were there.Must have run out of tape... Either way, I don't know what happened. No signs of water entry or damage. Weird. Just glad my door locks aren't cycling every time I turn the ignition switch now!!!
FYI to everyone else with 93-94 FACTORY INSTALLED SYSTEMS:
Keyless modules (black box with three harnesses, closest to your washer fluid box) will transfer over between 93's and 94's but the Anti theft modules (off white box with two white harnesses, immediately to the right of black box) WILL NOT!!! On the TSB I looked at on ALLDATA it showed 2 different part numbers and the parts guy at my local Ford Dealer verified this for me.a Trying to do so will cause major problems.
Also, if your truck didn't come with keyfobs and you have the electronics group you can buy one online. keyfobs with non rubber padded (aka... plastic) buttons can be programed to work with 93-97 explorers and rangers. TRW's (name of company who made them for ford) number for them is 3165189. FCC number is GQ43VT4T. If you find one with a blue trunk button, those will work too, minus the the trunk button.
