TedJ
- December 4, 2006
- NY
- '94 Sport
I bought my truck back in September and when I bought it the A/C worked slightly. It acted like the system was low but it was not hot out and I figured I'd mess with it in the summer when I needed it. It got warm a week or two ago and when I turned it on I got nothing at all. I figured I'd get some r-134a and charge it up. So i went to charge it and hooked up my gauge set. I looked to see if there was anything left and the low side gauge was off the scale. High side reads about 92psi. Compressor will not engage.
At this point i felt like I was in lala land and decided to check the system on my parts truck (which has working a/c dof!). With it off i had 65 PSI on both sides, and 28-30 on the low side and 100-110 on the high at idle with the ac on. So I know its not my gauges.
But then what is it? Is 92psi with the system off too high for it to engage? (its a lot higher than the other truck) Or is that right for this system and one of the pressure sensors is busted? Whats going on here?
Thanks Ted
Thanks Ted
