94 A4ld 2wd in 92? | Ford Explorer Forums
94 A4ld 2wd in 92?
piepoli1
Upstate, NY
'92 XLT 2WD
Will a A4LD from a '94 2wd just bolt in my '92 2wd 4.0 XLT? Isn't there something about a vacuum shift vs. electric? Adaptable? Thanks guys....
You shouldn't have any problems at all. The '94 will have the upgraded parts as a bonus, too. The A4LD from any 1st gen ex is interchangeable as far as I know. BrooklynBay or Glacier991 will be able to tell you for sure, though.
Where the A4LD is concerned, the vacuum controlled 3-4 shift was only used in the early A4LD's ('85 to '87). So your concern isn't applicable since you are using '94 and '92 A4LD's.
Thanks guys. Picking up the trans for transplant next week. Glad there should be no problems.
