94 b4000 loses power | Ford Explorer Forums
Keith A Swedberg
Hampton
1994 b4000 se
My 94 b4000 has an intermittent loss of power issue. It usually happens at highway speeds. It will refuse to maintain speed and also won't accelerate. After down shifting (it's a manual trans) and pedaling it a bit it usually comes back. Also I have had another intermittent problem when starting the truck. It usually fires up and then dies once. And the next attempt fires up no problem. But every once in a while it will take 15-20 attempts for it to start and then it stumbles at a very low rpm for a while until it levels out. I have replaced spark plugs (3 were very loose) wires are new. I also replaced the fuel filter.
Welcome to the forum!
Have you checked for any stored codes?
After checking for loose grounds and loose wires I unplugged the mass air flow sensor. Truck now runs like a champ! No stumbling. No hesitation on acceleration. Starts first time everytime.
