bansheeman1
- June 11, 2004
- Arkansa
- 94 sport
my 94 ex is acting crazy
it will allways crank, it may or may not start
holding it to the floor seems to help
when it starts it revs to 3000
then after a wile it goes down to 2000
if you turn on the a/c the check engine light turns on.
Some times it will die and not start back up
I put it on the scanner, no codes
when i unplug the scanner from the battery it changed the rpm
I also cleaned the throttle body and idle air valve
