budwich
- May 4, 2005
- Ottawa, Ont
- 96 XL
My rad shack VOM is the same... yep buzz is basically continuity... basically it is used to help keep your eyes on the test as opposed to trying to look at the meter and the test points. I would expect the readings to be a little lower but it depends on battery conditions and such.... when you touch your leads together... what is the reading???
I would try to measure to the first component in a run / trace as opposed to plug pin to connectors solder point. One other things... check out the inside of the plug (not sure which is female or male) but make sure the mating pins in the female are looking ok.
The bad news on this side... is that I am gone away til just before xmas... sorry but hopefully you will ultimately be successful in your effort... you are almost there.
