Don Coyote®
- July 11, 2006
- Michigan
- 94 EB
My mechanic says it's throwing several codes, the one that puzzles us most is the 212: "No Tachometer input to processor". (He has a very snazzy code-reader from "Snap-On" Tools).
According to the "Sticky" on codes that I just made a search on, it says... "Ignition module circuit failure/SPOUT circuit grounded".
It is also throwing out a 216 and a 217. (Primary coil circuit failure).
It's been running poorly for quite some time, but I blame that on a clogged catalytic converter. However, early this spring, I arrived at work just fine and spent the day as usual. Then, when I left for home, my engine ran COMPLETELY differently. It was quite adequate when I shut the engine off, but didn't run worth a damn after work. (I can't say it ran good,... but it ran ten times worse after work).
Last Fall, it got a new fuel pump, new FPR, new spark plugs, ... and this spring I put on a new ignition coil, (didn't need it,... ran the same), a different cam-position sensor, and a different EGR valve. (Both from a "parts" vehicle).
It doesn't want to idle, and it misfires. The tachometer seems to go psycho at times... in time with the hesitations in the engine. (I've never experienced a tachometer to be so affected by the performance of the engine).
My mechanic and I are pulling our hair out trying to figure out which module/sensor/coil/chipmunk needs replacing. (And HE doesn't have much hair left to begin with).
Please,..... if anyone out there can shine some light upon our dark dilemma, it just might ward off a new prescription of "Rogaine".
Thank you,..... Don® (Mike).
('94 Eddie Bauer Explorer,... by the way).
