satsuperman
- January 4, 2005
- Derby, KS
- '94 Sport
beginning about 3 months ago, not long after a top end rebuild, my 94 sport began to act like it wasnt getting any fuel and would not start. Now, about every 20th time I turn it over I get nothing except a turning starter but no start. I've replaced the fuel pump relay and I am getting spark to the plugs so my guess is fuel related. Tonight, it did it again and I tried pulling, cleaning, and checking all the connections at the relay/fuse panel. I then decided to check the fuel cut off switch. It was in the correct position so I began to jiggle all of the wire and check all of the connections, and after that, it started. I am beginning to wonder if that (cut off switch) is the culprit. If so, is there a way to just bypass it completely? Also, I am open to any suggestions on this matter since I think it is a connection / wiring issue?
