94 XLT No Power Brakes | Ford Explorer Forums
Michael B.
Ellicott City, MD
'94 XLT, 99 Explorer Spor
Well we finally dug out of the snow here near Baltimore. Once we cleared the vehicle I noticed some strange things on our 1994 Ford Explorer. In order to clear the Explorer from its parking space it was necessary to rock it back and forth for a little bit to get enough forward momentum to get to asphalt. Anyway, once cleared it was running very rough and it felt as I
lost the power to my power brakes.
I figured it may have been snow and ice packed in the wheels so it has not been driven since, just giving the snow a chance to melt. 50 degrees here today so it has melted-still no power on the power brakes.
The second thing I noticed when I turn the vehicle on now is that the tack fluctuates between 1600 and 600 rpms. After several minutes in settles to about 600 but it still runs rough. I noticed that the IAC valve looked
burned around the electrical connection so I changed it this afternoon. That seems to have taken care of the high revs upon starting but it still runs rough.
It also sounds like it lost a vacuum connection but I checked all the connections I could see and did not observe any disconnected vacuum hoses.
Its a 1994 Explorer XLT with 145,000 miles.
TIA for any suggestions. Its the wife's daily driver so I need to get it right and soon.
Mike
maybe it needs an oil change as well? leaving a truck sitting for a long time messes things up..... have you checked fluid levels? if in freezing temps, maybe the brake fluid is frozen, or was contaminated and somehow is messing things up now....
Sure sounds like a vacuum leak to me.Check the vacuum port at the rear of the upper intake manifold. Some have a plug on one of the nipples that may have popped off. Also check out the vaccum hose at the brake booster. It may be loose or even cracked.
Bill
Jim and Bill:
Thanks, I'll relook the engine this a.m. for any disconnected hoses. Mike
