Dennis94XLT
- October 11, 2002
- San Diego, California
- 2005 XLT
Hi everyone - I sure could use some help with my truck. Here's what is going on.
For past few months, only when restarting engine warm, engine would shake like a spark plug was mis-firing, but it would clear up instantly upon pressing the gas pedal. This has been intermittant - once a week and it always clears up right away when I press the gas pedal the first time. It doesn't come back again until the next time the engine is warm and it's in the mood to shake. I could live with that, but today: Engine warm and it would crank normally but would not start. I tried several times. The engine lights all seemed normal. The gas is 1/2 full - nothing has overheated either and all fluid levels are okay.
I opened the hood and tapped on the idle valve because I had a Sentra that wouldn't start when that went bad years ago - and retried the car - it starts now. I don't know if that was just a coincidence or not - or if the two problems could be from the same problem. Does anyone have suggestions about what to check? I am afraid I will get stranded if I don't get this fixed. The mileage is 80k and I do my own maintenence (which means oil changes, etc). I don't know where the check connector is - or even if getting a tester would reveal an error code with this type of situation or not.
Any suggestions are appreciated very much.
Thank you,
Dennis
Thank you,
Dennis
