George Scott
- April 21, 2007
- San Diego,CA
- 94 XLT
V6, 4.0L, 4WD, Auto. 168K miles.Infrequently and unexpectedly engine will crank but not start. When this happens, there is fuel pressure, but no spark. I have used a spray bottle and wet down selected areas (wires, connectors, modules) which did not help the diagnosis. It has happened in hot weather and cold, after sitting overnight and after a quick stop in the gas station when it's up to temperature. Problem does not appear to be related to temperature, moisture, altitude. When it starts everything runs fine. When it doesn't, it's like in the old days when you pulled the coil wire out of the distributor. Check engine light comes on at key-on but does not display when engine is running, and I have used a code reader and there are no codes in the memory. My Honda car had an intermittent ignitor once. Is this probably the same sort of failure ? I have a Chilton and a Haynes manual but they are both woefully inadequate regarding troubleshooting. I checked the Stickies and about 30 pages of posts after doing a search but most starting problems seem to be fuel related. Are my symptoms a commonly known problem with this year/model ? Can you provide a series of things to investigate. Thanks.
