95 EX Speedometer Problems | Ford Explorer Forums
bren7176
Downsville Ny
95 EX Sport/98 Ranger
I have a 95 Ex sport the speedometer started jumpiing up and down then died . the trans was shifting in and out of OD and the OD light was flashing when it did this. I replaced the Speed sensor on the Xfer case . The speedo shifts still jumps around and it still shifts wierd sometimes. What i asking does anyone know maybe what the problem is ??? Maybe a bad ground or wire . I have tried 2 new speed sensors and it still does the same thing ?? Is there anything I am missing ?? what should a check now?? where does the speed sensor go to after it leaves the sensor? where would the test point or ground be for this ? Anyhelp would be great..
