mike walsh
- May 7, 2001
- Red Bank, New Jersey
- 95 EB
Hi,
Would someone with a 95' Eddie Bauer please look under the hood and look at the hoses coming out of the heater to a vale 12" off it, and the hoses that go from the valve to the engine?
Whaterver that valve is called is doing the same thing as the old one I replaced, des[pite new hose, clamps and a the new valve. It has a small amount of coolant leaking and forming around the lip. I'm wondering if I have the hoses wrong and it creating pressure somehow that causes this. I just looked at a 97 EB but it does not have the valve and I think I might have the hoses reversed from the way it is setup.
I need to know the following from a 95 EB owner [although a 95 of any version might be the same].
1- there are two hoses coming out of the firewall. Does the one closest to the outside go into the top or bottom fitting of the valve.
2- does the hose that comes from the bootom and is attached to the water pump up to the valve go into the top or bottom fitting of the valve.
Thanks in advance,
Mike Walsh
Thanks in advance,
Mike Walsh
