1995ranger
- June 20, 2010
- 95 ranger
Ive waited to post but ive run out of possible solutions after weeks of reading posts. Before I start this site has been a wealth of information and I do thank the people for their expertise.
I have 95 ranger 2.3 4r44e after battling 2-3 flare and delay engagement issues and now I have no forward at all reverse ok. So far without going the rebuild route I have replaced the valve body to upgraded 4r55e with new solenoids ,band adjustments,replaced both servos ,nottomention several fluid changes and yes orings are on , just replaced internal wire harness (old had some cracking) and replaced range sensor appears to be properly aligned. Also replaced reverse servo and the new drings viton i believe with new gasket.
Thought i had it all set and went on test drive all appeared well and when I got home put in reverse to park car and then tried going into drive -there was no forward seems to rev but no movement but before the test drive there was a hesitation going into drive and i gave it some gas and bang into drive. The next couple of times shifting from park to drive there was no problem until I parked and then went to drive and nothing. I put pressure gauge on went thru the gears and a touch on low side but within spec according to alldata. Reverse was high but that gear seems ok.
Any suggestions to what I could try next or is dropping the tranny my next endeavor.There are no flashing od light and no engine light -no codes to go by so now Im screwed and dont know what else it could be.
