wolfman1979
- November 2, 2011
- 95 Ranger XLT 4.0 4x4
Have a 95 Ranger with a 4.0L, OBD-II with 100+ pin EEC-V PCM.
Speedometer/odometer stopped functioning recently, and following the advice from here (http://www.therangerstation.com/forums/showthread.php?t=18170) I tested the resistance at the VSS. My meter showed 205 or so ohms, well within the normal range but no speedometer.
I thought to try to repeat the test on the other end of the wire coming from the VSS, where it enters the PCM. Thinking was, maybe I have a broken wire. But before pulling the cover off the PCM, I wanted to ask if this is even a valid test. Plus, it seems from the wiring schematics I've looked at that there is only 1 wire feeding pin # 58, and I'm not sure how I would test for continuity with only one wire. Would I ground to the chassis somewhere?
Any advice/suggestions for testing this circuit downstream of the VSS itself would be appreciated. I haven't been able to locate much info, just that the signal from the VSS seems to go directly to the PCM. My local mechanic charges for plugging in the code reader, so I'm trying to diagnose as much as possible on my own first, and it seems like this should be something I can test ... if I can figure out how!
