95 X "limited" suspension options? | Ford Explorer Forums
Demon007
Rexburg, Idaho
'95 Limited
Hi its nice to see there is a site dedicated to the X. I just purchaced my 95 limited and found that I can't just go to the off road shop, buy a lift and slap it on. Does anyone know of a way to replace the existing air ride with an aftermarket one and lift er up? It's the wife's truck so I don't need to get too carried away, I want to throw some 31" bfg all terrains under it and keep it driveable 2 to 3" max. Any info will help, Thank You!
Demon007
Do a bodylift and keep the stock suspension. You should be okay with some 32's at that point.
You can search for bodylift on this site and find all the information about using the Ranger BodyLift on your Limited.
Thank you! I also noticed that when I put it in 4 low the 4 corners are all at different heights. The dr side only raises 2" and the pass 3", is there any way to adjust each air shock to make the ride even? thanks
