95-XLT-VT
- November 27, 2003
- Waterbury, VT
- 95 XLT
I've got a 95 XLT with control trac, about 110k miles. When I turn the selector knob to Auto 4WD, or 4 LO, both dash lights flash 6 times after about 3 minutes of driving, if I leave it in auto 4, it flashes again a few minutes later. It never flashes if I leave it in 2wd. If I set the switch to 4 LO, I can hear the case shift into 4lo, and out when I switch to either auto or 2wd. This means the shift motor is OK - right?
Here's what I've tried so far:
Unhooked battery for every attempt
Fluid change - No effect
Front and rear hall sensors replaced - No Effect
Unhooked and re-connected motor connector on transfer case - No Effect
Removed and re-installed GCM - No Effect
There is supposed to be a connection under the drivers seat - didn't have time to dig it out yet. Any other suggestions on what else I could check??? Thanks in advance.
