'96 5.0 Is there a trailer fuse/relay located under the hood? | Ford Explorer Forums
bmacd
Farmington, MI
'96 XLT 5.0
Looking at the Haynes/Chilton manuals, I can only see fuse #30 inside the door that relates to the trailer wiring. The CSR at the hitch shop said there was a fuse under the hood for my wiring. Is there any truth to this? I have 0.0v to my trailer harness.
-=bmacd=-
bump
-=bmacd=-
ttt
-=bmacd=-
-=bmacd=-
In the power distribution box under the hood, fuse #8 (20A) feeds all the trailer relays. (parking, and both signal relays) The brake/turn signal flasher input signal for the trailer turn signal/brake relays comes from the multifunction switch, and the trigger for the parking lights comes from the exterior lamp wiring fed from the switch. I suspect your fuse is blown under the hood.... It's not likely that both the parking light signal and BOTH turn signal inputs failed simultaneously.
Hope that helps!
-Joe
Hope that helps!
-Joe
I love you!!! I can't even tell you how long i've been searching for this answer. Sure enough, that huge fat fuse was blown out. I had to make a make-shift trailer adapter on my last trip by feeding the harness +12v from my amplifier in the trunk to have some running lights on my trailer.
Thanks again for your help. It's been a lot of headache.
-=bmacd=-
-=bmacd=-
LOL! Sorry 'bout that.... I would have responded MUCH sooner, but your original posts occured when I was in da great white nort chasing Bambi.
Glad you got it fixed! :)
-Joe
