Nothings changed. Had codes read because I know my CEL is burnt out. No codes....nothing. Had it done twice to double check and nothing came up then either.
Now it's doing it when I stomp on the gas at a stop light. It feels like an engine misfire for a second or two and then takes off just fine. Sometimes when I stomp on the gas to go(Trying to figure out what's wrong here) I get a popping noise from what sounds like the air filter box. Almost like it's not getting enough air or something. I checked the throttle body and the valve inside that opens and that opens just fine, like it's supposed to. I even did the zip tie trick on the gas pedal to make it open all the way up under full throttle. Nothing. Doing the same thing. I just changed the plugs and wires and it started to do this after I did this. Is it possible I got bad wires? If the gap on the plugs was off would it do this? If I sit at a drivethrough at a bank or something, sometimes I can feel the engine shake or miss and can hear what sounds like a plug wire of something arcing off of the headers or block or something like that off the wall of the drivethrough. What I don't understand about all of this is the fact that after I'm moving from a stop light, everythings fine. Shifts fine, and accels just fine. It's only from taking off from a stop or ideling....sometimes.
