MC05XLS
- June 23, 2007
- Seattle, Washington, USA
- 2005 Explorer XLS V6 2WD
So I've finally gotten around to changing my spark plugs, and it's good that I did as the ones I pulled were pretty well baked. During this upgrade, I installed Bosch Platinum +4 plugs, a K&N air filter to fit the factory intake, and an oil change to Mobil 1 5w30 full synthetic, in my 2005 XLS 4.0 V6 (FFV VIN letter K)
I changed the oil and installed the K&N first, as it was getting late, and didn't want to be working on plugs in the dark. But when I went to work the next day, as I was getting on the highway, the SES light started flashing slowly, and I noticed a change in engine performance. Once I got on level ground, engine performance leveled out, and the SES went out.
Next overpass, the engine stumbled again, the SES flashed, and something with the engine changed again, and it ran smooth.
The stumbling and stuttering kept on doing this both nights I worked.
Yesterday I installed the new spark plugs, and went out for a test drive. I'm still having the same problem. But, the problem is less than it was before I installed the plugs. I had to drive to Houston today, and I was hoping that between going over and coming back, maybe the computer would finally adjust and it would act right, but that didn't help. I disconnected the battery when I installed the plugs, and left it off for about an hour after, to clear the error codes. After my test drive, and seeing not much change with my problem, I disconnected the battery over night.
So now I have know clue what to do. Do I need to remap the ECU, and if so what program do I need and where can I find it? Would disconnecting the MAF sensor fix the problem?
One thing I've noticed, is I've gained about 1.5MPG average and at 65MPH on level ground the tach is now staying around 2,000RPM instead of between 2,750 - 3,000RPM. I'm not sure if that helps with diagnosis tho.
Please help!
Please help!
