'96 AC Questions | Ford Explorer Forums
'96 AC Questions
section525
sextion525
Moderator Emeritus
Red Bluff, Ca
1975 Ford Bronco 4x4
1. I put a nre motor in my turkc and i had to decharge the AC (legally :D ). Can I just add more freon until its full or do i need to vaccuum it through the system or what?
2. Refer to number one.
Vaccuum.
Depending on how long you had the engine out, and if the lines were capped, you should consider replacing the accumluator (also called the dryer).
I believe it's best to vaccuum with the engine compartment warm since this helps to get any water present into vapor form.
The pump I use is rated for 25 microns but since a gauge that reads down that far is around $500.00 I just make sure I have new oil in the pump and let it run for an hour at a time at two or three diferent times before I add the refrigerent.
Good advice.
Happy Exploring
CHRIS
Here's the deal. I am an A/C idiot so you guys need to talk to me like I'm seven.
Here's what happened.
I pulled the motor out, it was out for 6 days, nothing was capped. Now is the A/C something I can do myself or should I leave it to the Pros? I think it will cost me $80 to take it to my Uncle's shop. But I'd rather do it myself if possible.
So what tools, weapons, etc will I need and how do I do it?? :D
Thanks!
Section525
You should replace the accumulator to start. You will need a vacuum pump and a gauge set. There is a thread on converting, which has some good info. If you can wait a few days I am going to post a complete charge with pictures on a job I revcebtly completed on an old VW bus. That might prove helpful to some.
Happy Exploring
Chris
