tlein0718
- September 2, 2009
- st. joseph, mo
- 1996 ford eplorer
Ive read through many threads about this already. I have replaced the MAF and it did nothing. It has no power whatsoever, Im going to double check again, but i think all the intake hoses are good. I have replaced plug wires, plugs, ignition coil, (IC made it run ok rof awhile, but was burned up a few years back.
Basically anything underneath the shroud above intake manifold I have looked at/replaced and only for nothing at all. It used to run awefully loud, but that was fan clutch, now i can acutally hear it and there is no leaks that you can hear.
Also fuel injectors have been cleaned, new fuel pump. It runs so hard it maybe gets 7-10 MPG even onb highway, killin my pocket!
after it sits overnight/few hours you either have to hold down throttle or it will die. At stops I have to constantly hold my foot down on the pedal or it will die. Very rarely will it stay running good.
Dont know if this helps but when its cold it seems it runs better but takes forever to heat up. that in mind its a new water pump/temp gauge/gaskets.
Anybody have any advice? Im by no means a car mechanic, but more of a parts replacer lol. Thank you so much in advance
